I need help
I need help
Postby Mlking83 » Mon Aug 03, 2020 11:47 am
I live in denver just east of downtown. I can't seem to get the engine to stay running if no starter fluid is being used. Can anyone come give me a hand that knows more about engines than i do. New carb, new fuel pump but it dies as soon as it's out of starter fluid. Gas in filter beside carb. I just want to take it around the block to check my power steering work and brakes but i am lost when it comes to the engine at this point.
Mlking83
Re: I need help
Postby mickphatmac » Sat Aug 08, 2020 8:19 pm
We are going through the same problem with Cam’s Bronco.
He is about to swap out his third mechanical fuel pump in a year.
Our last fuel pump went bad in just under two weeks so you might start there?
Images: 14
Re: I need help
Postby Eck » Sat Aug 08, 2020 10:18 pm
I’d put an inline fuel pressure gauge close to the carb on it first to check that you are getting fuel pressure. Then you can start chasing issues from there.
I need help
Postby Kinder » Tue Aug 11, 2020 6:40 am
An easy test to check if the pump is working is unplug it from the carb and run it to a gas can where you can see the flow or not.
Send me a pm with your contact info and I’ll see if I can swing by and give some further advice.
