It is currently Tue May 07, 2024 12:58 am
[ 8 posts ] |
Tilt Column mechanism not working
Dang it man!!! Fix 1 thing, another goes wrong!??
So my ‘79 tilt column doesn’t tilt when you use the turn signal. You push it forward and you can feel it moving but it’s not engaging the spring-loaded mechanism on the bottom. Is the little black Doohickey missing something? Is there some sort of block or cylinder that goes on the end of it that pushes the Gold part (green arrow) up to disengage the teeth?
You can push on the little black thing with the white arrows and it moves but it just doesn’t connect with the green arrow part?
*** it does work if you push up on the part with the green arrow with your finger so the tilt mechanism is working, just not the part that engages it through the turn signal lever
On a sidenote, I drove the Bronco to Greeley today to work, yay!!! Then I took it to Les Schwab tire Center to get the alignment done only to be told that I need a new tie rod and drag link. Double Damnit!! No charge, just more money and more work. Only 13 more days to be Really Road Worthy!!!
Wed Aug 26, 2020 8:25 pm |
Re: Tilt Column mechanism not working
I have this column on BSD, I’ll look at it when I get home tonight.
Thu Aug 27, 2020 8:12 am |
ThankYou Buddy! What a pain in the butt, thank you very much!!!
Thu Aug 27, 2020 4:55 pm |
The tilt lever with the white arrow was bent down, below the spring operated mechanism with the green arrow, I just bent it back into shape and it’s good as new.
Fri Aug 28, 2020 6:09 pm |
Fri Aug 28, 2020 6:58 pm |
Ahh, too much man-handling!! So you bent it in towards the center of the column. Mine hasn't worked either so I need to investigate it.
Tue Sep 01, 2020 8:31 am |
Tue Sep 01, 2020 3:04 pm |
I see! The lever wasn't engaging the flap enough to get it to release the mechansim. Thanks!
Tue Sep 01, 2020 3:44 pm |
[ 8 posts ] |
