How to Prep
How to Prep
Postby B.O.B. » Wed Nov 11, 2020 8:51 pm
I am replacing my windshield frame and need to prep the cowl. What is the best way to prep it so I do not have issues after paint? Any help would be appreciated.
B.O.B.
Re: How to Prep
Postby phyler » Wed Nov 11, 2020 9:02 pm
If possible, clean the area really well. If bare metal is showing, put on an epoxy primer or etch primer.
When you set the windshield frame, use a drill bit or something to scrape off the paint/primer from the holes then you can weld to clean metal.
phyler
CCB Admin
Re: How to Prep
Postby B.O.B. » Wed Nov 25, 2020 10:28 am
On a side note. I am swapping over to a bolt on windshield frame and need fasteners. What have you all used?
B.O.B.
How to Prep
Postby Kinder » Wed Nov 25, 2020 3:25 pm
On the bolt on frames I’ve dealt with I’ve used flat (countersunk) style bolts so they don’t protrude into the hinge space.
Re: How to Prep
Postby landshark » Sat Nov 28, 2020 10:20 am
Counter sunk stainless hardware - make sure you put antisieze on the threads if you go this route
