Sudden electrical wierdness
- laffycaffi
Suddenly my gas meter stopped working. My passenger tail light wonΓÇÖt turn off, my driver side brake light wonΓÇÖt work, unless IΓÇÖve turned my left turn signal on - that activates my drivers side brake light.
Any ideas?
Any ideas?
- phyler
- CCB Admin
Re: Sudden electrical wierdness
With any electrical weirdness, start making sure your grounds are good. I'd look at a wiring diagram and see what all those have in common as well. Might be the plug under the hood right in front of the driver came a bit loose?
OG
OG
- Viperwolf1
The wiring harness going back along the frame has a problem. If you have exhaust running along the drivers side it's somewhat common to melt those wires.
- Kinder
IΓÇÖll add that since you just did a bunch of exhaust work you may have jarred the wires and made an almost problem a real problem. Look along the harness from the firewall back and see if the wrap (electrical tape likely) looks nicked or otherwise damaged and start there.
- laffycaffi
HereΓÇÖs a video of the wiring along the frame. Not really sure what IΓÇÖm looking for. Seems fine to me? https://youtu.be/3Xvg5lL3tgk
And here are some pics.
- laffycaffi
Good news. I cleaned the grounds at the brake lights and problem solved! But the fuel meter still nothing.
- phyler
- CCB Admin
Check the ground. [emoji16] It's back by the fuel tank. Easy for it to get crudded up. Had that happen on mine. Cleaned and my gas gauge has been consistent since.laffycaffi wrote:Good news. I cleaned the grounds at the brake lights and problem solved! But the fuel meter still nothing.
OG
OG
- Eck
And fuel gauges only work in 30% of Broncos so donΓÇÖt beat yourself up too much if it doesnΓÇÖt work!!
- phyler
- CCB Admin
Too true. Most that do work are off by 1/4 tank as well (reading 3/4 when full).Eck wrote:And fuel gauges only work in 30% of Broncos so donΓÇÖt beat yourself up too much if it doesnΓÇÖt work!!
OG
OG
- Eck
Guilty- and I replaced the wiring and sending unit.phyler wrote:Too true. Most that do work are off by 1/4 tank as well (reading 3/4 when full).Eck wrote:And fuel gauges only work in 30% of Broncos so donΓÇÖt beat yourself up too much if it doesnΓÇÖt work!!
- laffycaffi
Ha well thatΓÇÖs good to know. Did replacing the sending unit solve it for you?
- Eck
laffycaffi wrote:Ha well thatΓÇÖs good to know. Did replacing the sending unit solve it for you?
Sort of. My old one did not work at all and so I replaced it with a new one. However-- even that one isn't accurate like modern vehicles. At FULL it shows about 3/4 fill and when I am on E-- I know I still have around 1/4 tank. So it works well enough to use it so I never get stranded...
