Driver rear turn signal wire color
Postby la hi » Tue Jun 01, 2021 12:24 am
My driver side rear turn signal assembly has two wires, grey and brown. What do each of those wires do? Are they both hot? Is one a ground?
la hi
Re: Driver rear turn signal wire color
Postby Viperwolf1 » Tue Jun 01, 2021 9:32 am
Neither is a ground. The Brown wire is your running/park light. The other one is actually yellow and it's brake/turn signal.
Postby la hi » Tue Jun 01, 2021 1:54 pm
thanks viper
la hi
Postby la hi » Tue Jun 01, 2021 2:14 pm
I got the wire color. The yellow wire from the column to the left rear turn signal is a ground!!. How could it turn into a ground wire instead of a 12v ??
la hi
Postby la hi » Wed Jun 02, 2021 5:24 pm
Fixed it. It was the pigtail in the housing that was bad.
la hi
