Holy crap it runs. Electrical questions
Postby Gunnibronco » Sun Jun 06, 2021 12:30 pm
I'm very happy to say I hooked the battery up, and test fired the Bronco and it ran on the first try. icon biggin
Everything electrical seems to work except 2 things. I'll start researching but hoping someone will have some pointers.
Wipers only run on "High" and are noisy when they are running. I installed an intermittent wiper switch with the new harness. The destructions in the Centech kit were lacking, not to mention the addition of the intermittent wiper switch. I get nothing with the switch in the intermittent "zone" on the switch, or the first click. Only after the second click do they run, and have a noisy weird grinding noise.
Heater fan only runs with the switch on low.
For as much work as I did (and gutting the Centech harness to minimize excess wiring and customizing it my truck) I'm sort of surprised these are the only problems.
Re: Holy crap it runs. Electrical questions
Postby Gunnibronco » Sun Jun 06, 2021 1:10 pm
I corrected the original post regarding the blower fan. It only runs on low speed.
I've found this post and am guessing this is the problem/solution. It's low priorty since I have some version of wipers and I have lots more to do before mid July/Rubicon.
https://classicbroncos.com/centechwiperswitch.shtml
Also weird, when I use the horn, the turn signal indicators on the dash flash just slightly. The actual front/rear turn signals are not flashing.
Postby Gunnibronco » Sun Jun 06, 2021 10:19 pm
Some fussing with the wiper switch and I suddenly have all speeds. The bezel nut wasn't super tight and the switch turned clockwise after it reached the 'high' setting and all of the sudden I had a fully functional intermittent wiper switch. I'm not sure if that is good or bad. Sort of scary to have wonky electrical gremlins. But I tightened up the bezel nut and we've been good all evening.
The grinding noise was due to the linkage being a bit mixed up. I had the it clocked wrong on the passenger side wiper post. It was pushing on the motor output and pushing the gears together. I straightened out the linkage but there was too much in/out play on the motor output. I replaced the thin washer behind the linkage with a thicker one that helped keep prevent the output shaft from pushing inward and grinding the gears. All seems well.
As far as the fan, I think it's running on high speed with the switch on low. I have 12v to the motor. I'm assuming I messed something up with the resistor. It will have to wait. I hate that it's been so long since I wired everything I can't remember how everything hooks up.
Postby BroncoRaider » Mon Jun 07, 2021 2:34 pm
The Painless wiring guide is good and it's available for download for free.
https://www.painlessperformance.com/Manuals/10113.pdf
BroncoRaider
Postby Gunnibronco » Mon Jun 07, 2021 5:47 pm
Thanks. I'll look that over. I'm sure my Centech manual has something too.
Postby Eck » Mon Jun 07, 2021 6:52 pm
I had my wiring on the back of the heater switch jumbled up and so low was high and vice versa. Not sure if that’s what is happening.
Postby Gunnibronco » Mon Jun 07, 2021 7:26 pm
Eck wrote:I had my wiring on the back of the heater switch jumbled up and so low was high and vice versa. Not sure if that’s what is happening.
My guess is I mixed up hi/low and the wire from hi ended up getting disconnected. Makes sense.
