I'm setting up my front bump stops.
I had been using the typical bump stops sold for a lifted EB:
https://tomsoffroad.com/parts/66-77-for ... bump-stops
One is pretty chewed up from landing on an uneven place on my front axle after swapping in my full width D44.
I have a set of F250 rear bumps I pulled off a truck at work when installing air bags.
https://www.ebay.com/itm/184177700335?h ... Sw4OFeTY6V
I know they won't be as soft, and don't seem like they will give much at all. But they will do the job. I also pretty much know where they will stop everything from moving so they will be easy to locate.
Does anyone think this is this going to cause problems? Stopping everything with less give than the old stops?
I don't expect to be doing high speed/jumps/etc. I hope they will mostly be used at low speed/crawling, although we all know there will be surprises.
I suppose I can mount them and if I jar my eyeballs out I can always swap them.
