Started the disassembly of my 2150 carb today. Have a few questions to start and I'm sure more will come up. In the photo, there is a port at the back of the carb that has a hose that goes to a metal tube that used to connect to the exhaust manifold. I think this is called the heat riser? The metal tube broke off the manifold. I have not found a replacement and I'm thinking it's cause I don't know the right term. Would love some help there.
Second question is the YouTube videos all talk about a fast idle solenoid that has a wire hooked to it. Did all carbs have this? Mine doesn't have an electrical solenoid. It's more of a spring.
The insides are all pretty clean compared to some of the motorcycle carbs I've rebuilt. Last time this one was opened was in 1995. I wouldn't do it since it has been running well other than gas mileage is down and it sprays a bit of gas out of the weep hole on the accelerator pump. One of the screws that holds the accelerator pump is stripped out as well so I need to solve that problem as well.
