Cage tie-ins
Cage tie-ins
Postby Justin » Sun Aug 22, 2021 6:32 pm
I'm planning to tie my cage in to the body at the cowl (windshield bolts), top of the windshield, door posts, and at the back. Goal is to increase cage integrity a little and to decrease body shake a lot. Any reason this is a bad idea? I'm assuming the body doesn't need to move a little, but figured I'd double check.
Re: Cage tie-ins
Postby Digger » Sun Aug 22, 2021 8:02 pm
Been working fine for me. Stiffened up the body quite a bit.
Re: Cage tie-ins
Postby Trailpsycho » Mon Aug 30, 2021 9:45 pm
Mine mounts through the body to the frame at 6 points front of floor, B pillar a d rear corners...plates under the body with tube to frame....Bolts through cage-plates, floor and secured via under plates. Overkill, but zero flex in the body.
Hope to catch up with you soon Justin!
Cheers!
25th yr of ownership of my '76; ~3.5 yr frame-off restomod completed (100; 90+% by me) in '07 included '96 5.0 Explorer mated to NV4500, Terra Low D20, 4.88s F&R (ARBs) secured with Cage long arms and Deaver Leafs (5.5") topped with a Crab-style cage tied 6-points to the hot-dipped frame which rolls on 35" BFG KM2s on eagle alloys (flat back-as all trim) protected by sweet protofab plates F&R. it's never done. Just finished a delayed ( 3 yr) Explorer OBD-II upgrade, moved here. Now, needing to update emissions...seeking advice on that.
Trailpsycho
