You can get a loaner vacuum coolant leak testing kit at most auto parts stores. You can pressurize the system and then try to see if you can find where it’s leaking from.Gregg wrote:I've been having a slow coolant leak for a couple months and I can't see to find it. It's been pooling to the right and left of the water pump on the block (just below the heads which is why I think I had smoke in the engine bay coming back from Platte River Grill) ). It's also been running down along the oil pan on both sides. It seems to leak until the radiator is 2/3 full and then it stops leaking. I've checked hoses and none of them seem to have any coolant dripping from them. Any suggestions or tests to narrow this down would be great. Thanks!
Gregg wrote:I rented the kit today. I haven’t looked at any videos yet but I’ve got 3 basic questions before I run the test:
1. Should I top off the radiator?
2. Should I run the engine to circulate / warm the coolant
3. Any other advice
+2. If you're going to trouble of pulling the WP to replace the gasket, just do the pump.Eck wrote:How old is the WP? They’re relatively inexpensive and I’d be inclined to just replace it while you’re doing the gaskets since it’s a pain in the ass to change.
Gregg wrote: How can you tell if a water pump needs replacing?
I wonder if the new radiator had anything to do with it...
Gregg wrote:Thanks for the replies guys. Any thoughts on the breaking the seal on the old WP for a new one (#2)?
Also, I imaging I won't use the bottom corners or curved piece in this Timing cover gasket kit?
