intake torque setting's
Postby 71 bass boat » Sun Mar 13, 2011 2:41 pm
Does anybody know what i should torque my new intake manifold to? and in what order? it's an edlebrok performer if that helps i'm also looking to getting new bolt's for the intake. any info would help thank's!!
matt. beer
71 bass boat
Re: intake torque setting's
Postby Viperwolf1 » Sun Mar 13, 2011 2:50 pm
It's all on the last page of the instructions: http://www.edelbrock.com/automotive_new ... 0/2121.pdf
Postby 71 bass boat » Sun Mar 13, 2011 2:57 pm
thank's viperwolf any ideas on the bolts?
71 bass boat
Postby rtreads » Mon Mar 14, 2011 2:05 pm
...dont use crappy ones. ask me how i know
rtreads
Postby Viperwolf1 » Mon Mar 14, 2011 4:53 pm
I used studs for the intake. Ace has them.
Postby 71 bass boat » Mon Mar 14, 2011 6:48 pm
Oooh what happened with the crappy one's i'm always intersted in a good story!! popcorn
71 bass boat
Postby MOLLEY » Mon Mar 14, 2011 7:01 pm
mat there is a chilton manual in top draw in garage by da refrig you r welcome to go get it . i think they are 5/16 and 20 to 25 ft lbs .if i remember right . use some sealer around matting surface
cheers . Molley
MOLLEY
Images: 1
Postby MOLLEY » Mon Mar 14, 2011 7:02 pm
start toward middle and chris cross for pattern
again cheers Molley
MOLLEY
Images: 1
Postby ClayJ » Tue Mar 15, 2011 9:45 am
ClayJ
Postby 71 bass boat » Wed Mar 16, 2011 6:32 pm
Sweet thanks for the info guy's. the intake is going back on tonight!! hopefully will have the motor running by the weekend!
71 bass boat
