smell of gas.
smell of gas.
Postby gslack » Tue Mar 15, 2011 8:43 pm
recently, i dropped, and repaired my aux tank. i got new clamps for all the hoses, the are no leaks, and i sealed it up tight, and ever since i repaired it im getting the smell of gas in my cabin, and when i took the tank down i noticed there was massive rust under the drivers side (welding job anyone?) and it has been repaired, but not permanently, by another owner.
soo...could something have gone wrong...or...im kind of baffled. sometime next week ill be dropping both the tanks and replacing sending units, gaskets and wiring etc.
confusion :(.
help?
gslack
Re: smell of gas.
Postby sbolt19 » Tue Mar 15, 2011 8:50 pm
Check the collection canister right behind the driver seat in the cab. You could have pulled a line loose to that, there should be a rubber grommet/gasket that goes through the body that has 3 or 4 lines running to it. Look at that, it's just a vapor collector like the charcoal canister under the pass floor board and if when you pulled the tank it got the lines yanked a little hard.....
Also check your tank switch. A lot of times those things get knocked and you can pick up some fumes that way too.
sbolt19
Re: smell of gas.
Postby Viperwolf1 » Tue Mar 15, 2011 10:16 pm
X2 on the tank valve. It has an o-ring seal that is prone to minor leaks right under your legs.
Re: smell of gas.
Postby gslack » Wed Mar 16, 2011 7:17 am
thanks, the reason i repaired it partially is so i could come to the meet this saturday. next week ill take it apart and look up the schematics foreverything.
gslack
