Painting over a previously rattle canned paint job
Postby BNC04 » Wed Mar 23, 2011 9:31 am
I'm pretty much clueless when it comes to painting vehicles. I've seen several EB's that have a rattle can paint job which is usually either a primer or a flat color of some sort. I've been curious about what you would need to do if that were the case and you want to repaint with automotive paint? If I remember correctly, paint is very dependent on it's compatibility with the primer so I'm guessing it needs to be taken down to the last layer of standard paint type before re-primering and painting?
Any thoughts ?
Thanks
Brett
BNC04
Re: Painting over a previously rattle canned paint job
Postby Entourage » Wed Mar 23, 2011 1:38 pm
I sanded the majority of the PO Red Paint down to the maroon original paint, down to the primer, and in some spaces bare metal. I tried to leave as much of the paint and body work as possible to make things as easy as possible to repair later. I am definitely not a pro, but have done a little body work. So, I would say sand all of the rattle can paint off down to where you start seeing the original paint and body work, then build it back up from there.
I used a great paint remover pads from Eastwood (sanded much faster than sand paper) on a 6.5" Buffer. I think when you get down into the original paint you would be safe to build it , bacak up from there. Lots of guys will say sand to bare metal, but just as many think why re-invent the wheel and re-do what may already be done well.
I have read a lot of horror stories about mixing different brands of primers, paints, and clear coats. Sticking with one brand guarantees no issues. This is just my opinion and will be interesting to read other pro's ideas. I know GMAN, Zilla, etc. have a lot of auto body experience.
Postby BNC04 » Wed Mar 23, 2011 2:21 pm
Thanks for the info.. I'm primarily asking so I can factor that potential issue into the equation when I start looking at one seriously to purchase.
Brett
BNC04
