by akaFrankCastle » Tue Mar 29, 2011 9:13 pm
AA ordered the wrong wheel studs for me. No surprise there. Plus I'm waiting on my new brake lines to arrive. So I decided to mock everything up tonight to see if there were any more issue that would prevent me from finishing this install. And wouldn't you know it!!!
While test fitting the calipers and pads, I ran in to a clearance issue between the inner pad and the rotor. Here's some snapshots.
Spindle and backing plate mounted. Both from a 76 K10 4x4.
Clearance between the rotor and the rear of the backing plate.
Obvious lack of room for the pad.
Even tight with the pad from the outside of the backing plate.
So what am I missing here? I'm using the previously mentioned spindles and backing plates from a 76 K10 and rotors and hubs (new) for a 77 Bronco. Seems like there is a missing piece between the rear of the hub and the spindle that should be giving me the clearance needed to fit these pads.
