Viperwolf1 wrote:You've seen it. Just a '89 mustang block, decked and line bored. Stock crank, deburred. Stock rods, polished beams. Balanced rotating assembly. Stock HO cam, advanced 4 degrees. Stock forged pistons. AFR 165 heads, slightly milled. Compression ratio is about 9.7:1. Explorer intake manifold, serp system, oil pan and oil cooler. 19 lb injectors and A9P ECU. It's an economy engine, gets 30% better mileage than the stock 302/2bbl ever did and has 2 or 3 more horsepower.
B.O.B. wrote:Where does the Control for the temp go? Are putting it on the reyurn line back to te pump? Is there no need to use the bottom tube either? Thanks Viper for all your help.
