Need a rear center brake line ASAP
Postby Jesus_man » Sun Apr 17, 2011 7:12 am
None of my local parts store carry the stock hose. Anyone else know of a vehicle with the same 3/8" - 24 female with the same of longer line? It has a single fitting on one end a junction block on the other, all 3/8"-24 female. I am ordering from AZ, but would rather get this wrapped up today!
Re: Need a rear center brake line ASAP
Postby Viperwolf1 » Sun Apr 17, 2011 8:42 am
Raybestos # BH36851 for front and rear. About 7" longer than stock. I think that is from a '78-'79 Bronco.
Postby Jesus_man » Sun Apr 17, 2011 9:10 am
And it's half price!!! You rock man!!
Still not in stock but for 5" more!!
Postby Justin » Sun Apr 17, 2011 10:08 am
Wow. $9 on Amazon. I don't suppose you also know the part numbers (or vehicle, really-Raybestos has an awesome online catalog) for the front center and D44 to '78 Bronco calipers? I'm pretty sure the 76-77 caliper hoses work, but want to make sure before I order the wrong part. I was going to save up and do the SS lines from BC, but with these selling for 1/4 the cost I can't really rationalize it.
Postby Viperwolf1 » Sun Apr 17, 2011 11:20 am
Same hose as above for center front.
Napa UP36837 for right side, $16.41. UP36838 for left, $16.41. I think those last 5 digits are also the Raybestos numbers.
Postby Justin » Sun Apr 17, 2011 11:42 am
Awesome. Thank you! You just saved me about $100.
Postby Viperwolf1 » Sun Apr 17, 2011 11:55 am
Justin wrote:Awesome. Thank you! You just saved me about $100.
Put it in the college fund.
Postby Viperwolf1 » Sat May 14, 2011 12:29 am
The '78 hoses apparently don't work. These are the hoses for '76-'77.
UP 380974 left
UP 380973 right
Postby RJLougee » Sat May 14, 2011 8:29 am
Viperwolf1 wrote:Raybestos # BH36851 for front and rear. About 7" longer than stock. I think that is from a '78-'79 Bronco.
IIRC that's what I put back there when I built it JD.
Joe
RJLougee
Postby Jesus_man » Sun May 15, 2011 7:27 am
Actually I think u put the stock one in Joe. Which was adequate just worn out.
