Gathered up some parts today at lunch- Seal and bearings from NAPA.. they had the lowest price (or so I thought)
Pulled the passenger side off. Pieces started to hit the floor!
9 bearings,, Crap,, Looks like this turned into a removal of the 3rd to look for the remaining bearings.
Pulled the napa bearing out of the box,, Wrong part, these are not what I need from what I can tell..
Called Carquest, they have the correct bearings in stock.. Went and got them.
Pulled off the drivers side.
Different looking back side of the axle..
Drivers side on the left
The diameter is different than the passenger side also.
1.344 vs 1.236 though it tapers to the same measurement at the spline. Any thoughts on the axle being different? Maybe cut from a full size or something like that?
There was a small shiny spot on the pass side axle but I can't feel anything with dragging my nail over it.
I'm a little concerned about the difference and wonder if I should get new axles or not? Upgrading to 31 is not in the cards right now. Should I just re-install and run them until I decide. It obviously worked the way it way for a while.
Sure seems like I need to go diff diving for bearings as well unless I can get a long magnet and go
Brett
