Heater Box Install
Heater Box Install
Postby Entourage » Fri Apr 22, 2011 8:41 am
I am thinking of waiting to install my Heater Box till this fall and concentrate on things that will make it drive. Can I install the Heater Box without removing the dash and make all of the controls and power conections?
Re: Heater Box Install
Postby Viperwolf1 » Fri Apr 22, 2011 9:07 am
No problemo. I would run the cables and wiring now but the box can go in later.
Postby Entourage » Fri Apr 22, 2011 10:34 am
Perfect. That is just what I wanted to hear :D
Postby Justin » Fri Apr 22, 2011 12:19 pm
x2. Its a bigger pain with the dash in, but can be done. Be prepared to spend some time swearing at the heater box cables. Wear gloves when you do it. I didn't an ended up with insulation irritating the backs of my hands for several days. Surgical type gloves are best as you'll need as much feeling at the ends of your fingers as possible.
