by akaFrankCastle » Fri Apr 29, 2011 9:14 am
This morning a low level problem became a very serious one. Had a little vibration when not under load which quickly became a lot of vibration and popping when not under load. Climbed under the truck and found I've thrown a weight from the rear drive shaft. Also, looks as though I need to pick up some new U joints.
Need a recommendation for a good drive shaft shop in the springs to get everything balanced out. Also need some part numbers for ALL the U joints in the Bronco. Going to swap them all out now that I've had at least one go bad.
