Register •
FAQ
• Login
It is currently Fri Nov 22, 2024 5:54 pm
[ 4 posts ] |
SevenT
Joined: Sun Nov 14, 2010 8:16 am Posts: 24 Location: Colorado Springs
Twin Stick Shifting
Twin Stick Gurus,
I just completed my twin stick install on my Dana 20 that was originally a T-shift. Everything looks good and it does shift easier with the twin stick. I adjusted the shifters to match position when in 4 LO, the only problem I am having is engagement of the left rail (front driveshaft) in 4 HI. Any insight from those out there with a twin stick Dana 20?
TIA,
SevenT
_________________ 70 Bronco - '88 EFI 5.0 w/ RJM harness, JB Fab Twin Stick D20, AOD w/Art Carr shifter, 3.5" WH lift on 33s, 4.11s. Mods: Chevy disks in front, hydroboost parts laying in garage.
Wed May 11, 2011 5:20 am |
Re: Twin Stick Shifting
If you left the pills inside the tcase you need to put the rear side in range first and take it out of range last.
Wed May 11, 2011 9:23 am |
jbickhart
Ditto.....
on my D20 twin stick (not sure what pills are in it) when shifting into either LO or HI, the front axle must follow the rear. And, shifting back to neutral, the front axle leads.
Wed May 11, 2011 11:12 am |
SevenT
ViperWolf1 and jbickhart,
Thanks for the inputs. I will more than likely have to rebuild the D20.
v/r,
SevenT
Thu May 12, 2011 5:15 am |
[ 4 posts ] |
Users browsing this forum: No registered users and 20 guests |
