My seat belt harnesses bolt or clip directly to the floor. On my rear seat belt harness, I want to raise the rear mounting (like Justin recommends) and mount them to the cage since there is a rear harness bar. However, I do not want to screw/drill into the cage - only wrap the straps around using clips (if possible).
Is there a clip that goes on the seat belt harness, around the bar then back on its self similar to a 2 D-Ring Helmet straps under your chin?
Let me know if this is available and what the heck they are called.
TIA
