It is currently Thu Mar 28, 2024 3:49 pm
Good Technical Links and Pics
Re: Good Technical Links and Pics
Spicer Model 44 Maintenance manual. Complete with the worst photocopied pictures known to man.
Sat Feb 09, 2013 11:39 pm |
This just came across one of the Facebook EB groups I'm on.
Sun Apr 06, 2014 12:47 pm |
Fri Jul 25, 2014 6:27 am |
Frame Dimensions. Very helpful. Whoever made this did an amazing job. Scale is 1 pixel = 1/16". I have verified this with several dims. Although it has highlighted some inconsistencies with my own frame.
ETA: FYI - IN THE PROCESS OF CAD MODELING THE BODY, I FOUND A DISCREPANCY WITH THE FRAME PRINT. IT IS STILL A PRETTY GOOD PRINT, BUT THE REAR-MOST BODY MOUNT IS ACTUALLY 1" LOWER THAN THE VERTICAL DATUM LINE SHOW BELOW. THIS CAN BE VERIFIED BY MEASURING FROM THE UNDERSIDE OF THE BED FLOOR TO THE TOP OF THE MOUNT. THE REAR BODY MOUNT CROSSMEMBER ON THE BODY IS ~2" TALL AND THE MID-TUB BODY MOUNT CROSSOVER IS ~1" TALL, BUT BOTH ATTACHED TO THE SAME PLANE ON THE BODY.
Sun Jan 11, 2015 10:42 pm |
Dukietown
Mon Jan 12, 2015 5:14 pm |
Yup! Pictures can be uploaded to the site.
Mon Jan 12, 2015 5:58 pm |
Wed Jan 14, 2015 9:55 pm |
Dukietown
Thu Jan 15, 2015 10:06 am |
The most anal retentive differential set up I've ever seen. http://youtu.be/LjY33r0HVAcAnd it also happens to be the only one I've ever seen.
Fri Feb 13, 2015 1:49 am |
BroncoCrawler
Its nice to see someone else out there with my same illness of "perfection" when it comes to that sort of of thing. So many guys just toss a diff together and hope for the best.
Fri Feb 13, 2015 9:41 am |
Mon Apr 20, 2015 11:55 am |
Body diagrams. Not awesome, but the best I've found ebbodydims.jpg The whole set of files includes frame, chassis, and other info. http://www.supermotors.net/registry/media/1050287
Mon Jun 01, 2015 9:38 pm |
I'll post this one up too
Mon Jun 01, 2015 9:53 pm |
I stumbled on this Ford electronic connector identification guide today. http://www.fordservicecontent.com/pubs/ ... atalog.pdf
Mon Sep 28, 2015 6:20 pm |
Tue Nov 03, 2015 9:28 pm |
Standard vs reverse rotation water pump/timing cover ID.
Sun May 22, 2016 8:33 am |
TOOLMAN
Was out in my shop having a couple cold ones and was flipping through one of my manuals. I took some pictures of some pages some may like:
Fri Mar 17, 2017 1:57 pm |
D&D72
Gates hose guide.
Sun Apr 02, 2017 12:45 am |
Sun Apr 02, 2017 7:36 am |
D&D72
Sun Apr 02, 2017 8:34 pm |
Making your own Steering Shaft for Power Steering Conversions (with 3/4” - 36 x 3/4” DD) U-Joint
Cutting 3/4” Round (cold roll) bar into 3/4” DD for 3/4” DD steering shaft U-Joint
I bought 5 feet of 3/4” round bar for $7 bucks
I measured the length of the DD end at about an inch
I marked the steering shaft at approximately 1 inch all the way around the circumference And I marked at the end of the shaft approximately 1/8 of an inch from each side
You can use your grinder but I used my cut off wheel to cut straight down from the end to my 1” mark
After you have your rough cut, I switched to a sanding wheel and went all around it to get all the sharp corners off and make it slide into the U joint a little easier
Take your time and check the fit multiple times as you don’t want to take off too much metal you want it to be nice and snug inside the joint
Next I slid the U joint over the end and marked in the holes where I was going to drill for the safety screws - remove the U-Joint
Using a punch I marked the holes and I used an oversized drill bit and drilled about 1/8” into the steering shaft
Once again check for fitment and you’re ready to measure the overall length and do it again on the other side.
This is for a solid steering shaft with no welding. This does not include a collapsible steering shaft.
If this is the route you are going to take, good luck! I hope this was helpful!
Wed Aug 22, 2018 1:03 pm |
