www.ColoradoClassicBroncos.com - View topic - Who can fab me up a shim for my leaf spring?
It is currently Fri Nov 22, 2024 1:03 am
Reply to topic  [ 19 posts ]
Post Who can fab me up a shim for my leaf spring?
So to correct my lean I'm going to shim the left rear spring. I think I need at least a 3/4" block in there. Anyone available to cut one up for me? I do not have the tools to do this.
What I did was jack up the axle directly under the spring perch until the Bronco sat level. I had to go up at least 1" to make it look somewhat even. I had to go up 1.5" to get a level even on the rear bumper.
Any help would be greatly appreciated. I'd be happy to compensate with beer or $.
Thanks.
Thu Jun 16, 2011 5:18 pm
Post Re: Who can fab me up a shim for my leaf spring?
Dang! You work fast;) That is awesome Dan...thank you very much. So these are scaled to fit directly on the perch? Let me know what you think is a fair deal.
I can meet you just about anywhere....I'm not sure if I'll make the breakfast or not quite yet.
I am hoping 3/4" is enough:)
Thu Jun 16, 2011 5:38 pm
Hockydad may be headed to the breakfast....I'll send him a note and ask. Thanks!
Thu Jun 16, 2011 6:01 pm
Is that hole large enough for the WH springs? I think they use a bigger nipple than stock...maybe not.
Thu Jun 16, 2011 6:09 pm
Rox Crusher will pick it up Dan. Thanks again!
Thu Jun 16, 2011 9:00 pm
Images: 1
I was just curious twhy your truck would lean if you had newer springs. Something with the springs or frame?
Thu Jun 16, 2011 10:05 pm
Mystery lean. Some Broncos are born with it. Some contract it over time.
Thu Jun 16, 2011 11:07 pm
Sounds like some sort of early Bronco STD.
Thu Jun 16, 2011 11:08 pm
Thinking so. Side effects include frustration and shame.
Thu Jun 16, 2011 11:09 pm
Images: 1
The poor things, they take what ever we give them!
Thu Jun 16, 2011 11:21 pm
Dan....the center pin is 7/16". Is that what you have?
Thanks
Fri Jun 17, 2011 12:21 pm
Yea...it's the head of the center bolt that fits into the spring perch (or in this case will fit into that shim). You were right though, the bolt is 7/16 but the HEAD of the bolt is 5/8". If you could drill it out to 5/8" that would be sweet:)
Thanks.
Fri Jun 17, 2011 12:48 pm
I don't think you have that right airbur. This shim needs to bolt to the spring pack, so you may need longer centering bolts. (napa)
I just installed wedges on mine and if you set the head of your bolt into the wedge, there is nothing to hold the axle in the center of the spring. But if you run your bolt thru the shim, that holds it to the spring pack and then the bolt head still sticks down below the shim and into the spring perch.
Make sure you put a clamp on your leaf pack before you loosen the bolt. Also, make sure this clamp will not interfere with the installation of the shim.
Fri Jun 17, 2011 4:24 pm
Hmmmmm..... Getting confused. I think I get now that I have to get a new center bolt for the leaf spring pack that is longer and will bolt the shim to the sprin pack? That makes sense. The hole that is in the stock leaf perch is what I'm concerned with. The diameter of that hole needs to be the same as the head of the new center bolt...right?
Thanks
Fri Jun 17, 2011 5:40 pm
Fri Jun 17, 2011 5:53 pm
the hole in the perch is standard. There are two sizes of centering pins. 3/8" and 7/16".
Fri Jun 17, 2011 6:20 pm
If Rox does not make it, I will be there and glad to grab the shim from Zilla
I suppose I will see in the morning. If you decide to go and want to carpool up - let me know.
Greg
Fri Jun 17, 2011 6:55 pm
Thanks Greg! I can't make the breakfast.
Fri Jun 17, 2011 7:00 pm
Zill....thank you for the shim! I finally picked it up from Jeff yesterday. Got it installed. It has definitely helped with my lean. I think I am the only one that can notice it now.
Note to self: Bolt shim and leaf pack back together BEFORE remounting the spring on the perch. I tried it the other way around first and failed horribly.
Jeff....thank you for the longer center bolt! It was JUST long enough...by about 1/8"! I breathed a sigh of relief when I turned the nut the first time and it grabbed:)
Mon Jul 11, 2011 7:35 am
32,936,243 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
