www.ColoradoClassicBroncos.com - View topic - ARB line repair?
It is currently Fri Nov 22, 2024 7:39 am
Reply to topic  [ 7 posts ]
 ARB line repair?
Post ARB line repair?
Where do I get a repair splice for an ARB locker hose?
Or will a fitting from a hardware store work??
Tue Jul 05, 2011 10:25 pm
Post Re: ARB line repair?
Shot in the dark, but I'd call High Country 4x4. The ARB part number is 170206. Alternately:
http://www.4by4connection.com/arbairlocrep.html
Finally, it looks like Fastenal Part#: 0441394 also works.
Wed Jul 06, 2011 1:03 am
If I remember correctly the tube diameter is 5mm as well. At work we have 4 mm and 6 mm and I couldn't find any 5 mm when I needed some other than buying ARB. I remember seeing a link a few years ago on what fittings were needed to convert to 1/4 inch tubing. I will try to find that info as some may like that info and to carry as an emergency spare.
Wed Jul 06, 2011 7:22 pm
We carry a lot of metric tubing at work, let me look tomorrow to see if we have any 5mm couplers.
Wed Jul 06, 2011 7:35 pm
If I was in town, I would look, but I think I have some extra at the house about 5 feet w/ couplings
Wed Jul 06, 2011 7:54 pm
I found a coupling that I can just cut both damaged/melted ends and hook it right up. Shouldn't take any time at all.
Ya, you would think that someone else out there carries 5mm connections and fittings??
Thu Jul 07, 2011 9:26 pm
Images: 1
try.. flero fluids power .. 52nd and ward rd they had lots of stuff that fit arb but were not arb brand .im using pressure switch from them lower price and local
Thu Jul 07, 2011 10:30 pm
32,945,580 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
