www.ColoradoClassicBroncos.com - View topic - Stock power steering help!!
It is currently Fri Nov 22, 2024 9:50 pm
Reply to topic  [ 15 posts ]
Post Stock power steering help!!
Hi guys I got a dumb ass question but this thing is about to drive me crazy.. I pieced together a powersteering set up for my 66 and for some odd reason I cant get the power steering pump to mount to my 302...its a stock set up off a 302 so I was told but Im having trouble getting the two brackets to line up...is there more brackets then what I have?? I have the aluminum one that attaches to the pump and one metal one that i figured would come off the motor and mount to the aluminum one or something....I tried it many different ways and it dont seem to want to line up..anyone have any info or pics on this you can share??
Im your huckleberry
Tue Jul 12, 2011 7:33 pm
Images: 1
Post Re: Stock power steering help!!
Let's see pics of what you have. Is it a saginaw or ford pump.
Tue Jul 12, 2011 8:09 pm
its just the regular stock pump looks like half a paint can..it was the stock set up out of another early bronco..Ill post pics tomorrow..
Im your huckleberry
Tue Jul 12, 2011 9:59 pm
Images: 1
Tue Jul 12, 2011 11:01 pm
The pump mount should go against the head and the 2nd bracket will bolt to the water pump then over the corner of the steering pump and the long bolt will go through both brackets into the side of th head. Sometimes you might have to use a washer or 2 to line everything up.
Wed Jul 13, 2011 7:55 am
Something like this.
Wed Jul 13, 2011 8:22 am
Im your huckleberry
Wed Jul 13, 2011 1:35 pm
Well i tried it again today and it didnt seem to want to line up seems my water pump looks a little different from the one in the picture.. the two bolts wont line up maybe i need another bracket or something
Im your huckleberry
Thu Jul 14, 2011 12:27 am
can you post pics of your parts and pieces.........might help us
Thu Jul 14, 2011 4:47 am
Thu Jul 14, 2011 8:36 am
If I remember right, there needs to be a spacer behind the pump bracket (3/8" - 1/2") to line up the belt. Not sure if that could be part of the hassle too.
Thu Jul 14, 2011 10:29 am
ok here they are
Im your huckleberry
Thu Jul 14, 2011 7:20 pm
ok here they are
Im your huckleberry
Thu Jul 14, 2011 7:22 pm
Sorry the brackets are giving you trouble brother. I went out and looked at my Bronco and your water pump doesn't quite look like mine. No idea why. Looks like everything should line up though according to your pics. Just to make sure, you are trying to bolt it up 1->1 and 2->2 (see pics), right?
Thu Jul 14, 2011 8:22 pm
Not a big deal man i think vipers right they must have different brackets to different series of motors just need to find out which one now.. might be wise to just hit a junk yard and search for that bracket with the same waterpump if i can find one..
Im your huckleberry
Sun Jul 17, 2011 12:12 pm
Users browsing this forum: No registered users and 51 guests
32,959,374 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
