Register •
FAQ
• Login
It is currently Sun May 05, 2024 5:11 am
[ 6 posts ] |
cobshane
saggy rear end ha!
Make all the jokes you need, i can handle it.After installing the tire carrier assembly, im saggin. Anyone have a add a leaf or you think i can use the spare leaf setup i have and add on to the existing ones. I may have make a run to the bronco hut to get a leaf spring setup. I do want it to be right, but i am trying to save some kizash as well. I need maybe a extra inch or two.. this needs to happen before Ouray.
Wed Jul 27, 2011 7:14 pm |
cobshane
Re: saggy rear end ha!
Thu Jul 28, 2011 8:12 am |
What do you have for lift springs now? Mine did the same. Just replaced with new ones and it's sitting right now. However, I have some leafs that you could swap into your existing pack and maybe level it out. Trouble is it'd be trial and error and getting them to ya could be tough.
I have two longer leafs from a 5.5" pack, one 3.5" pack in tact and one 3.5" pack with two of the longer leaves bent.
Thu Jul 28, 2011 9:06 am |
cobshane
It has no lift in the rear. Dana 70 with higher spring perches made that possible. I already bought and paid for a set. Thanks for your offer though. Going with 2.5 wh leafs from the Hut. Just need to get down there sometime before the trip.
Thu Jul 28, 2011 1:09 pm |
airbur
Dana and Melissa happily meet up with me when I need stuff. Ask her if she'll meet you 1/2 way. Many times I25 and Lincoln is convenient for Dana.
Sun Jul 31, 2011 8:58 pm |
cobshane
Mon Aug 01, 2011 9:47 am |
[ 6 posts ] |
Users browsing this forum: Bing [Bot] and 8 guests |
