It is currently Fri Nov 15, 2024 3:31 pm
[ 6 posts ] |
4x4x2 box,77-79 F250 4x4 steering gear ok?
Does anyone know if the F250 steering gear box works for the 4x4x2 swap? I'm not sure if its the same as the F150/Bronco boxes I've read about. I found one, wondering if its worth picking up. Not planning the swap now, everything works good, but I wouldn't mind stashing the box & saving for later.
Chad
Fri Dec 23, 2011 1:31 pm |
Re: 4x4x2 box,77-79 F250 4x4 steering gear ok?
You may want to PM Cascadejohnson. Not sure how often he is on the board, but he does alot with these.
Fri Dec 23, 2011 1:37 pm |
Cool, I will,
Rock Auto shows different gears for F150s vs F250s, so I may have answered my own question, but I know there is really not much difference between most steering gears.
Chad
Fri Dec 23, 2011 1:40 pm |
sbolt19
Check West Coast Bronco's site. They have a complete walk thru on how to do it and what parts are needed.
Fri Dec 23, 2011 2:30 pm |
plumbdoctor
I just picked up a 78-79 box, and was planning on using the '80-96?? fi50 box, I think you can use the 250 box but some power stroke boxes have to be a certian one
Fri Dec 23, 2011 6:46 pm |
I remembered the WCB site and it doesn't look like the 70's F250 box works. You gotta start with the late 70's F150/Bronco 4x4 box, then you can use any number of boxes from the 80's-90's. Oh well. I really wish I had known about this when I had the 79 Bronco I pulled the axles out of.
Thanks Chad
Fri Dec 23, 2011 7:33 pm |
[ 6 posts ] |
