www.ColoradoClassicBroncos.com - View topic - Gears? 33's, C4 and 3.50's currently
It is currently Sat Nov 23, 2024 1:55 pm
Reply to topic  [ 17 posts ]
Post Gears? 33's, C4 and 3.50's currently
Looking into gears for the Bronco...302 EFI motor, 33x12.50's and C4...Currently running stock Dana 44 and Ford 9" with stock open 3.50's. It seems fine currently, the new motor added the power loss from the larger tires. Both the front and rear have 215k miles on them and I know nothing about working on them.
Should I look into 4.11's or just rebuild the current setup? What will the cost look like? Who should do them? Am I missing anything?
Royce
2006 4Runner V8 Sport Edition
Mon Jan 16, 2012 9:19 pm
Post Re: Gears? 33's, C4 and 3.50's currently
Totally interested Dan...Let me know what you want for them, also any advice on install?
Royce
Mon Jan 16, 2012 9:37 pm
Got yourself a deal on the gears and finding a weekend for the install. Thanks again as always Dan!
Royce
Mon Jan 16, 2012 9:52 pm
Is that a thick front ring gear? If not he's gonna need a new front carrier too.
Mon Jan 16, 2012 10:02 pm
Just a rule of thumb, be honest with yourself as what tire size you plan to stick with for a long time. There are many gear calculators out there, and you want to target the same drive ratio as you had with stock gearing and tires, maybe even a little lower numerically, to compensate for the heavier tires.
You can look at www.completeoffroad.com and many others to see what gear ratio's are readily available.
Tue Jan 17, 2012 8:56 am
Anybody have a used D44 open carrier for the 4.10 gears they want to sell? If not, Tom's has new ones.
Royce
Tue Jan 17, 2012 10:43 am
Tue Jan 17, 2012 8:04 pm
Awesome...Thanks
Royce
Tue Jan 17, 2012 8:07 pm
Royce
Wed Jan 18, 2012 10:14 am
Great thread. I will be moving to 33's in the next few months. I imagine I have the stock 3.50s (I"ll check before I do anything) but is it necessary to go to 4:10s.
most of my driving is around town with occasional short drives to a trail (60 miles).
No plans to go any bigger than 33's
Thanks.
Wed Jan 18, 2012 11:19 am
You can always upgrade your tires and see what you think, but with the extra load from larger tires, you work your tranny harder, and your engine, which could overheat both. Plus when adding 33's (and likely a lift) you increase wind drag and yet another factor to making your rig work harder.
However, Shawn, with those ghost flames, you get an extra 25 ponies at least. :)
Wed Jan 18, 2012 11:46 am
Wed Jan 18, 2012 7:54 pm
Royce
Wed Jan 18, 2012 10:21 pm
Wed Jan 18, 2012 10:54 pm
Thu Jan 19, 2012 9:50 am
Fri Jan 20, 2012 6:44 pm
Sounds like a deal :burnout:
Royce
Fri Jan 20, 2012 6:58 pm
32,974,228 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
