www.ColoradoClassicBroncos.com - View topic - Body mount bolt size and thread?
It is currently Fri Nov 22, 2024 2:23 am
Reply to topic  [ 3 posts ]
Post Body mount bolt size and thread?
Anyone know off hand what they are? 1974 bronco
Tue Jan 31, 2012 2:53 pm
Post Re: Body mount bolt size and thread?
Nevermind, I found the following list here: http://classicbroncos.com/forums/showth ... p?t=157661
Location Qty. Size Type Notes
Motor Mounts 2 1/2 Flat Washer
T-Case Crossmember to Support Angles 2 1/2 Flat Washer
Fender Support Brace Rods 12 1/4 Flat Washer
Cage Mounts 24 3/8 Flat Washer
Hardtop (Bedrails) 14 5/16 Flat Washer Use on nut or 2 per if not integral
Hardtop (Windshield) 9 5/16 Flat Washer Use on nut or 2 per if not integral
Seats (Front) 6 5/16 Flat Washer Stock is integral with CS
Seats (Front) 3 5/16 Flat Washer Stock is integral with CS
Torque Convertor STK 16 3/8-24 Flanged Stover Nut
Track Bar Mount (66-75, Axle End) 1 3/4-16 Castle Nut
Heater Core 4 1/4-20 Nylock Nut (GRD 8)
Cage Mounts 24 3/8-16 Nylock Nut (GRD 8)
Hardtop (Bedrails) 14 5/16-18 Nylock Nut (GRD 8)
Hardtop (Windshield) 9 5/16-18 Nylock Nut (GRD 8)
Soft Top Header 9 5/16-18 Nylock Nut (GRD 8)
Body Mounts 8 7/16-14 Nylock Nut (GRD 8)
Front Bumper (Hanson) 4 1/2-13 Stover Nut
Motor Mounts 2 1/2-13 Stover Nut
T-Case Crossmember to Support Angles 2 1/2-13 Stover Nut
Coil Spring Upper Mount 2 3/8-16 Stover Nut
Leaf Spring Hangers 4 5/8-11 Stover Nut Flange nut prefered
Leaf Spring Hangers 2 9/16-12 Stover Nut
T-Case Bushing Mounts 2 9/16-12 Stover Nut Stock uses 9/16-18 Castle
Track Bar Mount (66-75, Frame End) 1 9/16-12 Stover Nut Stock uses 9/16-18 Castle
9" Third Member 10 3/8-24 Stover Nut
Radius Arm Nut 2 3/4-10 Stover Nut Stock is Castle
Body Clip Nut STK 50 5/16-18 Short throat
Leaf Spring Hangers 2 9/16 Flat Washer heavy duty
Rock Skis 20 5/16 SS AN Washer
Soft Top Bedrails 14 5/16 SS AN Washer
Soft Top Header 9 5/16 SS AN Washer
Fenders (rear edge) 2 5/16-18 x .7500 PHMS Phillips head
Door Striker Post 2 5/16-18 x .500 CSK Screw Phillips head
Tailgate Catches 4 5/16-18 x .750 CSK Screw Oval head Phillips
Tailgate Release Handle Bucket 4 1/4-20 x .500 CSK OHMS Phillips
T-Case Crossmember to Support Angles 2 1/2-13 x 1.500 GRD 8 CS
Front Bumper (Hanson) 2 1/2-13 x 1.250 GRD 8 CS
Front Bumper (Hanson) 2 1/2-13 x 6.000 GRD 8 CS
Tailgate / Liftgate Anti-Rattle Tab 2 1/4-20 x .500 GRD 8 CS Stock with integral washers
Tailgate Release Handle Bucket 2 1/4-20 x .500 GRD 8 CS Stock with integral washers
Fender Support Brace Rods 12 1/4-20 x .750 GRD 8 CS Stock with integral washers
Cage Mounts 24 3/8-16 x 1.000 GRD 8 CS
Coil Spring Upper Mount 4 3/8-16 x 1.000 GRD 8 CS
Coil Spring Lower Mount 2 3/8-16 x 1.250 GRD 8 CS
Pedal Assembly / Brake Booster Bracket 2 3/8-16 x 1.250 GRD 8 CS Stock with integral washers
Pedal Assembly / Brake Booster Bracket 5 3/8-16 x .750 GRD 8 CS Stock with integral washers
Tailgate Hinge Pivot 4 3/8-16 x .750 GRD 8 CS Stock with integral washers
T-Case Crossmember Support Angles 8 3/8-16 x .750 GRD 8 CS
Door Hinge Post 12 5/16-18 x 1.000 GRD 8 CS Stock with integral washers
Hood Hinge 4 5/16-18 x 1.000 GRD 8 CS Stock with integral washers
Seats (Front) 9 5/16-18 x 1.000 GRD 8 CS Stock with integral washers
Tailgate Latch 4 5/16-18 x 1.000 GRD 8 CS Stock with integral washers
Core Support to Grille 3 5/16-18 x .750 GRD 8 CS Stock with integral washers
Fenders 14 5/16-18 x .750 GRD 8 CS Stock with integral washers
Hardtop Corner Posts 14 5/16-18 x .750 GRD 8 CS Stock with integral washers
Steering Column Firewall Mount 3 5/16-18 x .750 GRD 8 CS Stock with integral washers
Dana 44 Cover 10 5/16-18 x .625 GRD 8 CS Stock is flange head
Leaf Spring Hangers 4 5/8-11 x 4.500 GRD 8 CS
Bellhousing to Engine (C4) 6 7/16-14 x 1.750 GRD 8 CS
Body Mount (Front Clip) 2 7/16-14 x 3.000 GRD 8 CS Stock is 3/8-18, add for body lift
Body Mount (Driver/Passenger) 2 7/16-14 x 3.500 GRD 8 CS Stock is 3/8-18, add for body lift
Body Mount (Behind Front Seats) 2 7/16-14 x 4.500 GRD 8 CS Stock is 3/8-18, add for body lift
Body Mount (Tailgate) 2 7/16-14 x 4.750 GRD 8 CS Stock is 3/8-18, add for body lift
Radius Arm Caps 8 9/16-12 x 2.500 GRD 8 CS
Track Bar Mount (66-75, Frame End) 1 9/16-12 x 3.000 GRD 8 CS Stock uses 9/16-18
T-Case Bushing Mounts 2 9/16-12 x 4.000 GRD 8 CS Stock uses 9/16-18
Rock Skis 20 5/16-18 x .750 SS BHCS
Soft Top Bedrails 14 5/16-18 x .750 SS BHCS
Soft Top Header 9 5/16-18 x .750 SS BHCS
License Plate Frame Bracket 7 10-24 x .375 CS Thread Cutting
Heater Core 4 1/4 Fender Washers 1.000 OD
Seats (Front) 5/16 Fender Washer
Steering Column Firewall Mount 3 5/16 Fender Washer 1.250 OD
T-Case Crossmember to Support Angles 2 1/2 Lock Washer
Coil Spring Lower Mount 2 3/8 Lock Washer
T-Case Crossmember Support Angles 8 3/8 Lock Washer
Bellhousing to Engine (C4) 6 7/16 Lock Washer
Radius Arm Caps 8 9/16 Lock Washer
Body Mounts 8 7/16 Fender Washer 1.500 OD
Hardtop (Bedrails) 14 5/16-18 x .750 GRD 8 CS Stock with integral washers
Hardtop (Windshield) 9 5/16-18 x .750 GRD 8 CS Stock with integral washers
Leaf Spring Hangers 2 9/16-12 x 4.000 GRD 8 CS Flange head prefered
Liftgate support arm lower mount 4 1/4-20 x PHMS Phillips head, thread cutting
Radius Arm Bushing Washers 4 1.000 Fender Washer 2.500 OD
Tailgate Support Linkage 8 5/16-18 x GRD 8 CS Stock with integral washers
Track Bar Mount (66-75, Axle End) 1 3/4 Fender Washer 2.375 OD
Tue Jan 31, 2012 3:14 pm
Nice!!
Tue Jan 31, 2012 5:17 pm
32,938,829 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
