www.ColoradoClassicBroncos.com - View topic - Speedometer issues.
It is currently Sun Nov 24, 2024 12:32 am
Reply to topic  [ 17 posts ]
 Speedometer issues.
Post Speedometer issues.
I just replaced my speedo cable and when I drive my bronco the needle jumps all around. Is it possible that the gear in the transfer case is stripped out on the inside or a
Problem with the actual cluster? Has anyone else had this issue?
What did you learn?
Wed Feb 15, 2012 11:38 pm
Post Re: Speedometer issues.
Was it doing it before the speedo cable install? If it was, check out http://classychassisrestoration.com/. They will rebuild and restore the cluster, starting at $50. They've got a good rep over on CB.com.
Thu Feb 16, 2012 12:26 am
It has not worked since I have owned it. The needle stayed at zero before. Just not sure if it is grabbing intermittently.
What did you learn?
Thu Feb 16, 2012 1:02 am
Classy does a great job.
Thu Feb 16, 2012 3:35 am
Could be the cable sticking, but the gear is very easy to check and inexpensive to replace.
Thu Feb 16, 2012 8:22 am
There is the gear at the end of the cable and there is a gear inside the tcase that can slip out of place. Pull the cable/gear from the tcase and look at the gear inside the tcase. If it isn't square to the cable hole that's the problem.
Thu Feb 16, 2012 9:51 am
I'll take a look. Are we still on for this morning
What did you learn?
Thu Feb 16, 2012 11:02 am
Glad to see this post. Mine just started making noise and bouncing this winter. I've tried the graphite stuff on the dash side but that didn't do anything. I'll be checking the tcase cable sometime soon too. I've heard the cold weather makes all this worse.
Thu Feb 16, 2012 11:10 am
Thu Feb 16, 2012 6:08 pm
Mine was doing this....replaced the cable and it's fine now. If the gear is ok.....may be a bad...new cable.
Thu Feb 16, 2012 6:43 pm
He has a new cable. Gears look ok. Rubbing noises coming from speedo head when cable is spun. Something is wrong in the magnet and cup area.
Thu Feb 16, 2012 7:01 pm
An....I meant that maybe the new cable be had was bad. Sounds like you got it figured!
Thu Feb 16, 2012 7:09 pm
I'm not even sure how long it has been since the speedo worked last. I have had it for over a year and prior to that it was up in Craig out on a farm, so no telling.
What did you learn?
Thu Feb 16, 2012 7:43 pm
Just pulled out the cluster and disasembled it. Phil was right when he said there was a problem with the magnet. I hope I have fixed the issue. Since I have it apart I am repainting the needles and cleaning everything up. I will try to post pica after I finish.
What did you learn?
Thu Feb 16, 2012 10:55 pm
A pic would be great of the parts your fixing. If its not to late.
Fri Feb 17, 2012 9:14 am
Well I didn't exactly make the situation any better. The cup that has the magnet in it has now completely stopped working and the cup has a lot of play in it. I tried to adjust the magnets because they were hitting the odometer gears. The cluster looks very nice though. I'll mess with it a little more on my weekend to figure something out. If not there's always the option to send it in for a professional resto. I am unable to post pics because it always says I have too many pixels and can't adjust them on my dumb phone. oops
What did you learn?
Sun Feb 19, 2012 3:58 pm
www.tapatalk.com
Sun Feb 19, 2012 9:02 pm
32,986,926 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
