It is currently Sat Nov 23, 2024 10:24 pm
[ 11 posts ] |
Distributor among many others
patrickc
Joined: Sun Jan 02, 2011 3:37 pm Posts: 22 Location: Grand Junction
Among the many problems I have created for myself I have some new ones. First things first. I was replacing the Dizzy, probably really screwed that up and could not get it started again, and killed the battery very hard starting anyway. So i started all over went to TDC and reinstalled dizzy pointing rotor to #1 wire, figured if it would not start there I would only be 180 out. Installed new battery and it cranked over a few times but did not start. Went to crank it one more time and it will only click now and not turnover anymore. I barely cranked this battery and it is brand new and made sure battery connections were tight. So among the many laughs everybody can have about how many things I know I didn't do right, I just want to get it running again.
Fri Feb 17, 2012 5:52 pm |
Re: Distributor among many others
Battery can be new and cables could be corroded or have bad connections. Charge battery and clean all the connections. When I say clean I mean bare shiney metal. While the battery is charging find the compression stroke on #1 and set the distributor correctly.
Fri Feb 17, 2012 6:22 pm |
patrickc
Nothing is corroded and everything seems to be tight.
Fri Feb 17, 2012 7:36 pm |
May be too far advanced. Charge the battery and do the re-timing thing.
Fri Feb 17, 2012 8:21 pm |
airbur
You might put a meter on the battery to determine its charge. If its good, maybe you cranked the rest of the life out of the starter?
Fri Feb 17, 2012 8:34 pm |
patrickc
Took Battery back and it is fully charged, no corrosion on cables and everything is tight and it still just clicks. Could it be a bad relay, is there a way to test for this.
Sat Feb 18, 2012 3:06 pm |
patrickc
Well I got it to turnover, loose wire on the starter, it almost wants to start but I must be out of alignment in the distributor still.
Sat Feb 18, 2012 3:47 pm |
In the future, if you want to check your starter solenoid, you can use a remote starter. Or the quick and dirty way is to quickly short across the 2 terminals(battery & starter posts) of the solenoid, and see if the starter cranks. There will be some fireworks when you make the connection. Don't use a pair of pliers unless you don't like those pliers. Oh yeah, make sure the truck is out of gear.
Sat Feb 18, 2012 4:44 pm |
sbolt19
Sat Feb 18, 2012 5:28 pm |
I may have tapped a key with a truck on jack stands, in gear, once. I'm a quick learner.
Sat Feb 18, 2012 6:46 pm |
patrickc
Most be getting closer, it almost starts but backfires. I think I'm about done for the night.
Sat Feb 18, 2012 9:16 pm |
[ 11 posts ] |
Users browsing this forum: No registered users and 9 guests |
