It is currently Sun Sep 29, 2024 1:28 pm
[ 12 posts ] |
airbur
Blinker/Hazard Gremlin
Sometimes when I use the blinkers both left and right blink at the same time....like they should with the hazards. Does this mean a relay is going out somewhere?
Sun Mar 04, 2012 10:33 am |
Re: Blinker/Hazard Gremlin
Probably a bad turn signal switch.
Sun Mar 04, 2012 11:15 am |
airbur
Sun Mar 04, 2012 11:29 am |
Oh. Could be a short between terminals/wires on the column connector. The GM connector has left and right signals on adjacent terminals. The troublesome firewall connectors are like that also on the '71 and older Broncos.
Is it just the dash indicators that are lighting up or the actual signals, front and rear?
Sun Mar 04, 2012 10:03 pm |
Shawns Fords
did you check the blinker fluid?
Mon Mar 05, 2012 9:29 pm |
airbur
Tue Mar 06, 2012 8:18 am |
RJLougee
Tue Mar 06, 2012 4:01 pm |
It comes in right turn or left turn bottles.
Tue Mar 06, 2012 4:12 pm |
ClayJ
In our cold weather, you probably only want 20 weight, or they'll blink too slow
Tue Mar 06, 2012 5:06 pm |
Shawns Fords
Mon Mar 12, 2012 9:49 am |
Lila76
Joined: Mon Oct 24, 2011 12:02 pm Posts: 111 Images: 0 Location: Aurora, CO
Would your piston return springs be going bad?
_________________ What did you learn?
Wed Mar 14, 2012 9:12 pm |
airbur
Thu Mar 15, 2012 5:11 am |
[ 12 posts ] |
