www.ColoradoClassicBroncos.com - View topic - Tire size and speedometer correction
It is currently Sun Nov 17, 2024 7:46 pm
Reply to topic  [ 9 posts ]
Post Tire size and speedometer correction
A thought just occured to me, if I go to 31" tires the speedometer will be off a bit. How do you correct this? In my 94 i can do it through the gauge computer.. i assume for the 76 its replacing the speedo gears that go into the transmission? i might as well take care of this while i have everything out...
Tue Mar 06, 2012 11:22 am
Post Re: Tire size and speedometer correction
Just a change of the gear on the end of the speedo cable. Easy to do after everything is together. I recommend driving it with GPS to determine the actual error in speed first. You'll need a gear with either 1 or 2 less teeth. Math will help determine the closest match.
Tue Mar 06, 2012 11:37 am
got it thanks!
Tue Mar 06, 2012 11:44 am
Ought to look something like this:
Actually, I can't confirm that. That's what my Atlas has and I think it was design after a different t-case.
EDIT AGAIN:
according to the BC Broncos site, they are plastic:
http://www.bcbroncos.com/dana20.html
Tue Mar 06, 2012 4:15 pm
Yup - and just an FYI - Colorado mustangs unlimited off Peoria and 37th has them in stock (same as the ones in my son's C-4 (66 stang). Actually it is fairly impressive how many small parts are shared between our rigs and the classic mustangs.
Wed Mar 07, 2012 9:16 am
All D20's use the manual trans version of the speedo gear. It's shorter than the auto trans version.
Wed Mar 07, 2012 5:56 pm
Guess. That's what I did until I changed the gears in the axles, then I went to bigger tires & now I am guessing again. shrug
Wed Mar 07, 2012 10:37 pm
It's simple. If the driveshaft is turning 10% slower (tires 10% taller) you need the speedo cable to turn 10% faster. Gear needs 10% fewer teeth to turn the cable 10% faster.
Wed Mar 07, 2012 10:49 pm
Naw, what I actually have done in the past, and it is pretty close right now even, so it doesn't worry me, is I gauged it off of mile markers, did some quick math in the ole bean and figured out that I was roughly 6-10% over what I am really going. My rig was originally set up with 3.50 gears, and when I had 31s I was over a little. Then I changed the speedo gear when I went to 33s and it corrected it. Then I went with 4.10/4.11 gears and it under corrected and now with 35s it is pretty dern close.
Thu Mar 08, 2012 11:11 am
32,893,910 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
