www.ColoradoClassicBroncos.com - View topic - Best location for recovery hooks?
It is currently Sun Sep 29, 2024 3:22 am
Reply to topic  [ 13 posts ]
Post Best location for recovery hooks?
Where does everyone have them? Bolted/welded?
Sat Mar 17, 2012 7:24 am
Post Re: Best location for recovery hooks?
Depending on how your bumper is mounted placing them on top or below the frame horns can work well. If I remember correctly you're running stock bumpers, I'd put them on the bottom of the frame rail. Just back them with a piece of 3/16ths plate steel to spread the load on the rails.
Sat Mar 17, 2012 7:20 pm
Good thought. Zillas way is better.
Sat Mar 17, 2012 8:39 pm
Any preferred type of hooks? Brand etc?
So with the 2x4 tubing...you're essentially spreading out the load along the frame a bit? By stub....about how long?
Thanks.
Sun Mar 18, 2012 6:44 pm
The best type of attachment is something that cannot come loose:
Hooks don't work well. Even the ones with a keeper because the keeper always breaks at some point.
So to complete the package you'd need a couple clevis', a good tow strap with loops (not hooks) and maybe a bag to carry them in. I also like use these with metal loops for strap storage.
As for straps, you can get some really good ones at 4x4 parts stores. Bubba Rope is also good. But I cheap out and go to a farm supply store and buy them for much cheaper rated for 27,000lbs. 30ft is a good length.
Mon Mar 19, 2012 8:41 am
Mon Mar 19, 2012 1:16 pm
Mon Mar 19, 2012 1:27 pm
Mon Mar 19, 2012 2:28 pm
Brown Noser.
Mon Mar 19, 2012 3:24 pm
Mon Mar 19, 2012 4:25 pm
ive got hooks bolted and welded to the bottom of my frame. Same with booger. And both have seen a lot of abuse with no issues so far.
Mon Mar 19, 2012 4:39 pm
Mon Mar 19, 2012 4:51 pm
Tue Mar 20, 2012 9:04 am
32,372,131 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
