www.ColoradoClassicBroncos.com - View topic - violently shifts into reverse
It is currently Sun Nov 24, 2024 9:06 pm
Reply to topic  [ 5 posts ]
Post violently shifts into reverse
Hi guy's
After my wifes prank of listing my bronco on craigslist to get me off my A$$ it worked!
302 with C4
violently shifts into reverse.. it can chirp the tires when I select reverse *THUWMP!* when it goes in..
Loud Clunk noise! if it needs rebuilt WHO and WHERE should I send it?
Tranny fluid is full, But leaking banghead
"Friendship is like peeing on yourself: everyone can see it, but only you get the warm feeling that it brings."
!974 Bronco, 4x4, 302/ auto trans, All original for now
Thu Mar 22, 2012 12:52 pm
Post Re: violently shifts into reverse
If you need a rebuild or have questions, you are in luck. The best C4 guy in the country is ViperWolf and he is here in Colorado. My ViperBuilt C4 shifts like a Lexus.
Thu Mar 22, 2012 1:01 pm
Check for excessive idle speed and slop in rear driveline. A linkage adjustment may help too. Disconnect linkage at trans, put trans lever in neutral, put shifter in neutral, re-attach linkage. Might need to re-adjust NSS afterwards.
Too full can cause leaks. Oil level should only reach full mark when trans is really hot, idling in park.
Thu Mar 22, 2012 1:25 pm
Fri Mar 23, 2012 6:59 am
I agree with Viper. Check idle speed, mine does it as well. I have the idle set at about 950 so it will idle at about 650 in gear. Talk about jumping when put in gear and it does build up a lot of heat when idling sitting at a light. A little higher stall rpm would help.
Fri Mar 23, 2012 8:40 pm
Users browsing this forum: No registered users and 17 guests
33,014,729 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
