www.ColoradoClassicBroncos.com - View topic - spare tire mount solution
It is currently Sun Nov 24, 2024 3:30 pm
Reply to topic  [ 4 posts ]
Post spare tire mount solution
I have my spare tire mounted on the stock swing arm spare tire mount. But it's pretty pathetic - the spare hanging off of it by a single long bolt and that weird looking giant wing nut thing. How's that for technical lingo?
I'll try to post a pic later if you need further illustration but I am wondering if there's anything out there, like an adapter mount that attaches to the stock swing arm that will mount a spare more securely than this (which is what I have): http://broncograveyard.com/bronco/i-153 ... e-set.html
Mon Mar 26, 2012 3:00 pm
Post Re: spare tire mount solution
Are you running a stock tire size or are you running bigger? If you run bigger tires, I hope you plan on putting the carrier on the bumper because it will cause body damage eventually. But as for the original setup goes, meh...it's a design that needs to be improved on to secure the tire from would be thieves. You can put a pad lock on it. I don't remember what the original carrier looks like. Haven't had one in almost a dozen years.
Mon Mar 26, 2012 5:06 pm
Ran into the same problem. Had a bit of a budget (none), so came up with a quick solution. Not the greatest, but seems to work and keeps everything where it should be (running 33's). Seems to hold up when I used to bounce around with Kirk and crew!
Essentially ran a strap to the mounting bolt to keep it in a decent position. After that, still not happy and welded up a quick little frame that puts most of the weight on the bumper. My latch was done (did let the tire go at some time), so decided to not use it all. Grabbed a few clips from the hardware store. Also put some chaffing material in to keep from rubbing on the bumper and bracket. Only thing I did not like was drilling a hole through the bumper. Currently have an eye bolt through it to keep the bottom portion stationary. Hasn't come loose yet, so it will stay for the time being. Takes a few seconds to get the tire out the way and access the back.
Here are a couple of pics.....
Not great, but works!
Matt
Mon Mar 26, 2012 8:10 pm
Mon Mar 26, 2012 10:29 pm
Users browsing this forum: No registered users and 25 guests
33,005,441 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
