www.ColoradoClassicBroncos.com - View topic - Need brake hose from MC to H-block
It is currently Sun Nov 24, 2024 4:36 pm
Reply to topic  [ 11 posts ]
Post Need brake hose from MC to H-block
Broke mine today banghead
It's metal & rubber. The fitting for the MC is larger than the standard 7/16" brake line, but the bottom end is the 7/16". None of the normal parts store site have it on there. Maybe I am looking in the wrong location? Thanks!
Mon Apr 30, 2012 2:32 pm
Post Re: Need brake hose from MC to H-block
At one time I went looking for the brake line adapters. I thought there was no way I'd find them in Gunnison. I was in Denver and looked at about every parts store I could find (Auto Zone, Advance, etc). No one had them. I went to my Carquest (Big A) at the time and they had about every adapter I could imagine, even metric x std. My Napa has them too. They are in the bins behind the desk, not out on racks. Good luck. If you come up short, I have a few m/c lines that didn't fit, from my full brake line kit, and ones I took off when I went to HB. They are all steel lines w/loops, none w/rubber.
Mon Apr 30, 2012 5:19 pm
I hate to add an adapter (another point to leak), but I have gone down that road a few times. I can get a custom one made, but they are kinda spendy... I'll take it into whistler tomorrow and see what they say. Thanks!
Mon Apr 30, 2012 5:21 pm
Yeah, I made my own with metric on one end and std on the other when I went HB. I wouldn't know where to find a line w/2 different ends.
Mon Apr 30, 2012 5:23 pm
Try the Parker store on Garden of the Gods before Whistler. I went there to get a hydro line fixed a few weeks ago and they were great. Knocked it out while I waited and didn't make me feel like I was a non-commercial burden on them.
Mon Apr 30, 2012 5:54 pm
I called Parker first. I'd much rather give them the business. But they said they don't do automotive brake lines due to the liability...
Mon Apr 30, 2012 6:47 pm
Dang it! I just trashed our old ones two weeks ago when I'd did the discs. The rubber was cracking but they weren't leaking and would have bought you some time:(
Mon Apr 30, 2012 7:43 pm
It's ok. I'll run to whistler tomorrow. I have some time before I can do anything with my front locker anyway. I don't suspect this holding up getting my bronco going again.
Mon Apr 30, 2012 8:56 pm
JD I'll be at the yard tomorror if you want to stop by. Probably can get you fixed up.
Mon Apr 30, 2012 10:18 pm
Tue May 01, 2012 7:29 am
Whistler is going to be really proud of their lines, especially if they have to make them. I don't even try to replace the stock lines anymore. I buy a pre cut four foot length of 3/16" brake line from Orileys. Usually you can get at least one correct fitting out of the two on it. Wrap it around something with about a 2" diamter three times to give a little flex between the frame and body and then fit it in. You only need to make one double flare and can use your original fittings if you need to. I have a flaring tool if you need one.
Tue May 01, 2012 9:35 am
Users browsing this forum: No registered users and 28 guests
33,006,945 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
