Register •
FAQ
• Login
It is currently Fri Sep 20, 2024 11:20 am
[ 3 posts ] |
wing window seal replacement ??
Brianut
Any pointers or advice on swapping these?
Fri May 11, 2012 11:55 am |
sbolt19
Re: wing window seal replacement ??
You have to completely remove the main window to get the wing window assembly out. When you go to pull the wing out, open it up and pull it towards the back of the door. Just be careful not to bend the front part of the frame. But just take your time, pay attention and you will do fine.
Fri May 11, 2012 12:30 pm |
sbolt19
Actually, you don't have to remove the main window, but it does help. I fought with it until I just pulled the glass out and then the wing popped out real easy. But remember, if you leave the crank window in, there will be nothing to support it on the front side. The wing support structure is the entire front rail for the crank window.
Fri May 11, 2012 12:34 pm |
[ 3 posts ] |
