www.ColoradoClassicBroncos.com - View topic - AOD with 4R70 internals
It is currently Thu Sep 19, 2024 3:13 pm
Reply to topic  [ 3 posts ]
Post AOD with 4R70 internals
Has anybody posted a write up about the AOD rebuild with 4R70 internals?
1976 Sport, 302, C4, 4.11 rear 4.09 front, 3.5 in lift,33's...............
Thu May 31, 2012 10:23 pm
Profile YIM
Post Re: AOD with 4R70 internals
....I would guess a lot of people would consider this option as no expensive computer or electronics are needed. Is there really any big negative to installing the 4R70w internals in an AOD... other than you cant lock up the converter?
Sun Jun 03, 2012 9:24 pm
The 4R70W also allows you to control shift points electronically, with a Baumannator. I don't know if an AOD has any weaknesses compared to a 4R70W otherwise. But I'd like to know if the 4R70W is better/stronger. I'm guessing you could use the gears from a 5.4L 4R75W, they are supposed to be the same as 4R70W, but stronger. I don't know this for sure, just from reading:
http://www.tccoa.com/articles/tranny/tr ... ndex.shtml
http://www.lincolnsonline.com/tech/00080.html
I thought I had more, but here is a little info. At the bottom of the page, there is some specific discussion about adding the wide ratio gears to the AOD.
http://www.becontrols.com/tech/ch3aodeupgrade.htm
Sun Jun 03, 2012 10:20 pm
32,275,979 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
