need a template for drilling holes for my "bronco" emblem
Postby Brianut » Thu Dec 09, 2010 8:07 am
Anybody have any idea where these holes should be?
I have replacement fenders on mine and was wanting to put the "Bronco" back on and thought it would be nice to have a template of where to drill.
or does it really matter that much?
just get it close and straight and go for it?
Also anybody know what size the holes are?
Brianut
Re: need a template for drilling holes for my "bronco" emble
Postby Kinder » Thu Dec 09, 2010 7:52 pm
I can give you measurements from the emblems to any spot on the fender, but I don't have the holes or pattern, will that help?
Postby Brianut » Mon Dec 13, 2010 7:22 am
yes that would be good.
not sure where to measure from or to since the emblem is not on there not sure what would be best.
Let me know what you come up with.
I am planning on making the meeting this saturday and so far I have much to do before that happens, hopefully I can get the badges back on by then.....
Brianut
Postby ClayJ » Mon Dec 13, 2010 12:38 pm
I hear ya. They are hard to drive without the Bronco emblem on them poke
ClayJ
Postby chrlsful » Mon Dec 13, 2010 2:23 pm
Brianut wrote:Anybody have any idea where these holes should be?
:idea:
Try 3.5 "and 12.25" for OEM. Use yer emblem as the template. There R (what 6? 8?) some pins/pegs or whatever dat stick out da back o de emblem. The lowest /furthest toward the bottom/frnt of the "B" is the lill # from the left frnt door edge (again, Passenger's side). De bigger # is from the hood/top-o-de-fender-meeting-edge. If U understand/like/need I'll gib ya the driver's side too. U don't really need it if ya gots 1. For the other 5 - 7 holes juss take a level n strike a line.
Hope that helps rather than confobulates!
shrug
Chad
'70 LUEB on '77 chassy, 4 discs, 4.1, NV3550, PTO, DSII, RBS, 1" WH BL, 2"SL, spray lined tub, sno plow, tool bxs, etc.
chrlsful@aol.com
SEEKING: 16 inch auger/drill for the PTO
chrlsful
Postby Brianut » Tue Dec 14, 2010 6:47 am
Vragor wrote:I hear ya. They are hard to drive without the Bronco emblem on them poke
leaves no excuses for somebody to call it a jeep then. rant
nuthin against jeeps, I just dont own one.
Brianut
Postby Bitch'nBronco » Tue Dec 28, 2010 10:28 am
Other option... put masking tape where you want the emblem big enough for the whole emblem to fit. Then put grease blobs on the leading edge of the mounting pins . Make sure the emblem is square and then touch the emblem to the tape... then mark your holes where the grease was (or just drill where the grease was) and you'll be set. Easiest way I can think of, saw a guy do it on another forum.
Bitch'nBronco
Postby dsmith01 » Wed Dec 29, 2010 8:49 pm
Which replacements did you buy? Just curious because the dynacorns I just bought came pre-drilled. Thought it was interesting that the "Bronco" emblem was pre-drilled but the side marker light hole wasn't.
1972 EB - Fuel Injected 351w, 33s, detroit rear
My Personal Website - Home of D-Rock
dsmith01
Postby Brianut » Thu Dec 30, 2010 7:09 am
not sure whos they are as they were on the truck when I got it.
just got my retainer clips for the emblems yesterday so I will be getting this taken care of soon.
I think with the measurements posted I should be able to get it close enough and then make sure they are matched.
Brianut
Postby Kinder » Thu Dec 30, 2010 8:25 am
You still need to pick up those hubs, and since yours is on the road you could just come on by and take a few more measurements from mine icon biggin
Postby Brianut » Mon Jan 03, 2011 9:59 am
I know, life has been kinda crazy these last couple weeks.
what time do you get home this week?
I will be passing through around 5:15-5:30 ish as I am on late/on call shift.
BTW saw you headed south at lin/jordan yesterday afternoon at around 4:15.
Wife says hey theres a Bronco, oh its not a new one, just Kirk :^)
I was looking to chase it down.
Brianut
Postby Kinder » Mon Jan 03, 2011 5:40 pm
That time works for me, except tomorrow (Tue) when I'll be home later, give me a ring Wed - Fri and we can meet up.
