Viperwolf1 wrote:This is applicable to almost everything. Before you take something apart take digital pictures. When you're taking it apart bag/label the parts. Take more pictures. When you have an assembly taken apart put the bolts/screws back in there original holes if possible so you so you know where they all are and where they go.
Brianut wrote:Viperwolf1 wrote:This is applicable to almost everything. Before you take something apart take digital pictures. When you're taking it apart bag/label the parts. Take more pictures. When you have an assembly taken apart put the bolts/screws back in there original holes if possible so you so you know where they all are and where they go.
along the lines of this.
Muffin pans work great for keeping nuts,bolts or screws together where they belong.
just use some tape to mark each muffin hole as to where those parts came from.
Colorado75bronc wrote:if installing a body lift and you don't have access to a shop lift, set e-brake and chock the wheels, loosen one whole side of the body a couple turns on each bolt, remove all the bolts from the other side, and use a 2x4 or 4x4 thats as long as your rocker panel or close to and a highlift jack, 2 preferably for safety, but you can with one, complete the body lift on that side of the truck, tighten the completed side down snug, repeat on the other side, also air hammers/air chisels make easy work of removing stubborn old bodymounts
ZOSO wrote:Good idea. Here's one that I use.
For anyone running a carb off road should have the spring loaded needle and seats. Also a trick I use is put a fuel pressure regulator in. And when going wheelin turn it down to 2psi or so. Just DONT forget to turn the pressure back up before hitting the road or you'll run it lean. The lower fuel pressure keeps the carb from flooding when the floats are bouncing.
Jesus_man wrote:For your carb'ed guys - my dad (a diesel mechanic) told me to run a gallon of diesel in with the gas to help prevent vapor lock. Diesel has a higher boiling point so the mixture seems to give you a few more degrees before the fuel with turn to a gas.
