www.ColoradoClassicBroncos.com - View topic - Transfer Case Bolts
It is currently Sat Nov 02, 2024 1:39 pm
Reply to topic  [ 10 posts ]
 Transfer Case Bolts
Post Transfer Case Bolts
Anyone know off the top of their head what size bolts I need to mate up the transfer case to the end of the transmission?
Tue Sep 04, 2012 9:00 am
Post Re: Transfer Case Bolts
Not sure, but consider using studs with nuts instead. The t-case is kind of the pain to align otherwise, especially if you're installing it solo.
Tue Sep 04, 2012 9:23 am
Really? Wow, I never thought of that. It is kind of a bear to wrestle around underneath the Bronco. Good idea, thanks!
Tue Sep 04, 2012 10:10 am
Don't thank me, I stole it from Viper. Will be doing this to my rig after I rebuild my spare D20.
Tue Sep 04, 2012 11:12 am
Now, I'll be doing something like that tonight or tomorrow. Thanks for the tip, just in time. It is not easy to balance that thing on a jack and get everything lined up, especially alone.
Tue Sep 04, 2012 11:59 am
T-cases are difficult at best to install. Their center of gravity is just not conducive to wiggling it around without the proper equipment. SO anything you can do to help the process is money and time well spent. Wish I knew the size, but I do not.
Wed Sep 05, 2012 1:15 am
Aren't they 3/8-16?
1966 Bronco (Aug. 1965 production date), 5.0L Explorer EFI, 33x12.50 BFG AT
Wed Sep 05, 2012 1:35 pm
Profile YIM WWW
I will be checking tonight! I will let you guys know. Thanks!
Wed Sep 05, 2012 2:17 pm
I checked mine and they're certainly 3/8-16. I'm switching mine out for studs when I put the t-case back in.
Thu Sep 06, 2012 9:55 pm
Profile YIM WWW
Good to know sir -- thank you very much!
Thu Sep 06, 2012 10:33 pm
32,757,514 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
