www.ColoradoClassicBroncos.com - View topic - Brake line size
It is currently Thu Oct 31, 2024 9:47 pm
Reply to topic  [ 3 posts ]
 Brake line size
Post Brake line size
Any reason I can't use 3/16th brake line from the M/C to the prop valve for both front and rear? Tried 5/16 for one of the circuits so that I wouldn't have to use an adapter, but am having problems with it kinking badly.
Thu Dec 13, 2012 1:16 am
Post Re: Brake line size
You can run 3/16, that's all I run for my entire brake system. And unless you've replaced it, the thing on the frame is not a prop valve, just a brake imbalance warning switch.
Joe
Thu Dec 13, 2012 11:47 am
Thanks! I dropped in a factory prop valve from a '76.
Thu Dec 13, 2012 12:02 pm
32,735,323 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
