It is currently Sat Jun 22, 2024 7:52 pm
[ 8 posts ] |
B.O.B.
![Post Post](./styles/acidtech/imageset/icon_topic_latest.gif) In tank efi fuel pump ?
Has anybody tried to flare the sending unit line inside the tank to create a better seal. It seems that whatever I try to do it won't hold pressure. I don't want to keep tightening clamps because it seems like it keeps cracking the hose after a couple of runs on the pump. What have you guys done?
Sun Dec 01, 2013 1:06 pm |
RJLougee
![Post Post](./styles/acidtech/imageset/icon_topic_latest.gif) Re: In tank efi fuel pump ?
What tank, lines, clamps and pump are you using?
I have the BCB tank and run a Walbro 225 pump, using high pressure EFI hose and EFI type clamps. I've never had an issue with this setup not maintaining pressure, except at one point the pump came unbolted and was moving around in the tank. HTH, Joe
Sun Dec 01, 2013 1:31 pm |
I have the BCB tank with internal pump. I abandoned the one they provided as the mounting clamp couldn't be tightened enough so it vibrated around on the bottom of the tank, within the clamp.
I now run a Aeromotive 11140 which is nice and quiet.
I use EFI hose and clamps too.
If you have a BCB tank, just get a longer piece of hose so you can run it up further on the pick up tube and put two clamps on it.
Sun Dec 01, 2013 3:11 pm |
B.O.B.
Rox did you clamp your pump like Airbur did. Where did you get your clamp for the pump at?
Sun Dec 01, 2013 9:46 pm |
Mon Dec 02, 2013 1:42 am |
airbur
The clamp and pump. ![Image](http://img.tapatalk.com/d/13/12/11/marubuhy.jpg) ![Image](http://img.tapatalk.com/d/13/12/11/8abuzeny.jpg)
Tue Dec 10, 2013 8:42 pm |
B.O.B.
Mine is a Aero tank that the Hut sold for a bit. A little different configuration but might give som Ideas on how to fix my situaton.
Tue Dec 10, 2013 10:25 pm |
B.O.B.
I think all it needed was for me to come out to the garage with a beer, Johnny cash on pandora, and of course a new set of injectors that don't leak. Holding pressure strong at 32 psi when primed. Been there for ten minutes with the key off. Before it would be down to 10 psi by now.
Fri Dec 27, 2013 9:12 pm |
[ 8 posts ] |
