www.ColoradoClassicBroncos.com - View topic - PS hose with 4x4x2 box
It is currently Sat Nov 16, 2024 9:50 pm
Reply to topic  [ 17 posts ]
Post PS hose with 4x4x2 box
I just did the 4x4x2 box conversion and i used west coast broncos 3/4" adapter plate. Now i can get my line onto the box due to my fitting hitting the frame. Any ideas???
Is my only option to get a power steering hose made that screw straight into the box and not use AN fittings? And hope the clears the frame.
Mon Jan 06, 2014 2:04 pm
Post Re: PS hose with 4x4x2 box
Ive got sone 90 degree fittings you can have
Mon Jan 06, 2014 2:44 pm
What kind of 90's do you have. Right now I have AN fittings and I thing that part of the problem is I have to use a adapter to go from the box thread to AN
Mon Jan 06, 2014 2:55 pm
There are low profile 90 degree (non adapter) fittings out there, I think we used them on Willem's Bronco. When he gets home from school I'll look at his setup.
Mon Jan 06, 2014 3:14 pm
Great thanks.
Mon Jan 06, 2014 3:16 pm
mine are an -6 for a hydro ram should work
Mon Jan 06, 2014 3:46 pm
so then does that -6AN 90 you have screw straight into the box making it so I wouldn't have to use the blue adapter shown in the pic?
Mon Jan 06, 2014 4:04 pm
Let me find them and take a picture. .text me 7209360791
Mon Jan 06, 2014 4:16 pm
No luck using Willem's setup, he has an adapter. I bet E&H (http://www.emrickandhill.com) can solve the problem locally. Hopefully Trei has a solution.
Mon Jan 06, 2014 5:52 pm
Mon Jan 06, 2014 9:27 pm
Mon Jan 06, 2014 9:28 pm
That looks like what I need! Where did you get that 90?
Mon Jan 06, 2014 11:25 pm
Now that I look at it again it needs to be inverted flare.
Mon Jan 06, 2014 11:43 pm
They should work for you. . There free so you haven't lost anything. . My parents live in hr. Text me your info I will have him bring them that way
Tue Jan 07, 2014 8:16 am
These will attach to the blue an fittings and swivel anywhere you want .
Tue Jan 07, 2014 8:27 am
I will look at Drews tonight, I do not recall having any issues with the lower hose clearance. We are also in HR so you are welcome to swing by and take a look at his set up.
Tue Jan 07, 2014 8:45 am
Thanks Trei, I just sent you my info. Is that 90 -AN on both sides? If so then yes that should work great.
Hockeydad- If Trei's fitting doesn't work I'll let you know and maybe I'll come look at Drew's set up.
Tue Jan 07, 2014 10:26 am
32,889,442 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
