www.ColoradoClassicBroncos.com - View topic - spongy brakes I need help bleeding I think
It is currently Sat Nov 23, 2024 8:32 pm
Reply to topic  [ 11 posts ]
Post spongy brakes I need help bleeding I think
I have been trying to bleed the brakes solo and I think I'm sucking air into the system. I have brakes but I have to pump up pressure. I think I need a pedal pumper and be able to watch the flow. Here is my setup cuz everyone asks
JBG booster kit
Disc disc proportion valve
Gm rear calipers
3/4 ton front brakes
New lines from Mc down to axles
Have no leaks as far as I can see.
Bleed valves are up as much as possible
Booster has vac
Adjusted pin on booster into Mc
I bought a mity vac but it seems to be a little hard to keep it sealed
Any advice
Thu Mar 13, 2014 9:46 am
Post Re: spongy brakes I need help bleeding I think
I can swing by one eve and assist.
Thu Mar 13, 2014 10:51 am
I assume your doing one wheel at a time. I always start with the furthest back from the mc - passenger rear then work my way forward.
You really need someone to pump the brakes while you open and class the bleed screw.
I open. Pump 3-4 times then pedal all the way down close screw. Let up on pedal. Then pedal down and open screw. Then close screw. Pedal release. Pedal down. Open screw. Repeat 6 or 7 times until no air bubbles seen.
Sometimes it helps to not open the bleeder fully as some air sneaks in at the screw. Also I always run a clear tube off the bleeder screw into a bottle to help the mess and watch.
This works for me but your mileage will vary ;)
Thu Mar 13, 2014 10:57 am
Ive had lousy luck with vacuum bleeders. Youre on the right track getting help.
Thu Mar 13, 2014 11:04 am
If all else fails,I have this.It will suck the Chrome off a trailer hitch.
Thu Mar 13, 2014 12:02 pm
It's just almost impossible to do it solo. I prefer old school bleeding procedure and closing the bleeder on a down stroke
Thu Mar 13, 2014 12:32 pm
I have only gravity bleed once. But got lucky. Usually have to get the wife to help
Thu Mar 13, 2014 12:54 pm
I would prefer aanother person to put eyes on it as I'm not subjective anymore. I'm kinda pissed;)
Thu Mar 13, 2014 1:04 pm
I'll be heading up ur way Saturday morning to swap my trailers, I could swing by early.
Thu Mar 13, 2014 1:09 pm
where are you located I have a pressure bleeder. Alex
Thu Mar 13, 2014 1:26 pm
I'm in Se aurora. . That Would Be Awesome For Sat Morning.
Thu Mar 13, 2014 1:46 pm
32,982,591 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
