www.ColoradoClassicBroncos.com - View topic - It's finally done my build is done
It is currently Sat Nov 23, 2024 2:25 pm
Reply to topic  [ 13 posts ]
Post It's finally done my build is done
So here are some pictures. Before and after
Sat Mar 15, 2014 5:50 pm
Post Re: It's finally done my build is done
That's awesome, must feel good to see all that hard work pay off. What tire size were you running and what's on there now? Also, what spring rates did you settle on for the front?
Sat Mar 15, 2014 6:03 pm
37 to 39.5 tire
Spring rates are 225 over 250 I'm pretty sure
Sat Mar 15, 2014 6:48 pm
That is one bad mo-fo. Really nice work and turned out great. Looks like it can go anywhere with all those hi-end parts. Love to see more pics of the rear suspension. Very well done build.
Sun Mar 16, 2014 12:45 am
That is sweet.
Sun Mar 16, 2014 8:03 am
Looks great trei. Can't wait to see it in Moab ;)
Sun Mar 16, 2014 9:51 am
Test drive complete wow this thing is crazy
couple small issues
1. Brakes such need to bleed
2. Clearance front drive shaft yoke and adjust pinion angle a little
3. Clutch seems to be chattering a little. 3.54 to 4.88 gears maybe a little worn out or need to get use to it?
Sun Mar 16, 2014 3:04 pm
Looks great on the dirt, chatter is usually a worn clutch disk or bad springs
Sun Mar 16, 2014 8:09 pm
Looking at your flex shots, it says something when the front on an EB can move that freely.
Sun Mar 16, 2014 8:21 pm
I think I nailed the geometry. But we will see
Sun Mar 16, 2014 9:02 pm
I'll most likely give you a call this week. I'm hoping to start mocking up the front end when my axle brackets come in.
Sun Mar 16, 2014 9:14 pm
Congrats! I know you've worked hard on it! I hope with a few tweaks here and there you enjoy the heck of out it!!
Mon Mar 17, 2014 8:04 am
How do you like that radius arm setup?
1996 bronco 4bt sas .
1972 bronco 10k mi no motor no trans..unfortunately rolled in 1973. Left for me to bring back from the dead.
Mon Mar 17, 2014 1:21 pm
32,974,590 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
