It is currently Tue Jun 25, 2024 11:06 pm
[ 5 posts ] |
![Post Post](./styles/acidtech/imageset/icon_topic_latest.gif) 3G wiring
I have the following alternator:
http://www.ebay.com/itm/1992-93-94-95-9 ... mp;vxp=mtr
Am I to believe this is not a true 1-wire alternator? How would I connect this alternator to the AAW harness I bought from WH?
Am I better off getting a different alternator or will this one work with this harness? Do I need to do some reconfiguration of the wiring
Fri Mar 21, 2014 4:54 pm |
![Post Post](./styles/acidtech/imageset/icon_topic_latest.gif) Re: 3G wiring
What you have is what you want. They aren't "1-wire" alts, but from what I read, they are better than 1-wire models, I forget why. One wire will trigger the alt from a 12V switched source. And one heavy gauge wire runs to the battery. You can run a ground wire too. Sometimes they don't ground through the case the way it should. I think this is what you have: http://www.bcbroncos.com/3G%203%20wire% ... 20mark.pdf
Fri Mar 21, 2014 5:18 pm |
Thanks. Makes more sense now. And I have the wires. ![Image](http://img.tapatalk.com/d/14/03/22/5epupa6a.jpg)
Fri Mar 21, 2014 5:32 pm |
crawlercreations
The larger yellow wire can be cut and looped right back to the large charging stud and the green wire with red tracer should be connected to the green wire with red tracer wire going to your stock regulator/alternator. Add a large 4 gauge wire with 150 amp fuse going directly to your battery and you are all set.
Fri Mar 21, 2014 7:04 pm |
I had a buddy having trouble with his charging system one time. He had just installed his 3G. Neither of us not knowing much about it, we looked at his setup and he had one 12ga wire running somewhere and I told him that wasn't right, but he was adamant about it being a "one wire setup". He must not have even had that one wire hooked up right because it should have melted thru within minutes!
Sorry, still know little about it, but sounds like you're getting good help!
Wed Mar 26, 2014 8:20 am |
[ 5 posts ] |
