www.ColoradoClassicBroncos.com - View topic - Sealing dipstick port
It is currently Sat Nov 23, 2024 8:48 pm
Reply to topic  [ 9 posts ]
Post Sealing dipstick port
I'm about to drop my oil pan to replace my rear main seal. The piece that's riveted into the oil pan to accept the dipstick leaks a decent amount between that part and the pan itself. What's the best way to re-seal it? Drill the rivets and use RTV or can it be welded without warping the pan?
Thu Apr 03, 2014 3:28 pm
 Re: Sealing dipstick port
Oh,, I thought you meant Gregg was mouthing off again. :) :laughing2:
Thu Apr 03, 2014 3:44 pm
Post Re: Sealing dipstick port
A friend of mine brazed his and it worked out great
Thu Apr 03, 2014 6:46 pm
Profile WWW
If you are going to drill out the rivets I'd make a gasket for it. I think it could be welded fairly easily.
Thu Apr 03, 2014 7:40 pm
Mine leaks on the 76. Interested in this as well.
Thu Apr 03, 2014 10:38 pm
Couple of guys over on CB.com suggested brazing it. That might be the ticket, as the filler rod would wick between the two parts in a way that a weld wouldn't.
Thu Apr 03, 2014 10:41 pm
I have this same problem. I was just considering welding the hole shut with a piece of sheet metal. Or just a new pan w/o said port...
Tue Apr 08, 2014 4:05 am
Tue Apr 08, 2014 8:56 am
:beer: what time:)
Tue Apr 08, 2014 12:17 pm
32,982,941 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
