It is currently Sun Sep 29, 2024 11:34 am
[ 6 posts ] |
Space between radiator and fan
Just want to confirm I'm good. I've got 1.5 inches between the two now.
Thu Apr 10, 2014 7:59 pm |
horseplay
Re: Space between radiator and fan
Looks good plenty of space and close enough to create a proper draw with fan shroud.
Thu Apr 10, 2014 8:16 pm |
Is the 1.5" down at the bottom of the fan where it is usually the closest ?
If so, good.
I had a flex fan that was about 1" at the bottome and it ate the radiator when I hit a big pothole.
Fri Apr 11, 2014 4:50 am |
Fri Apr 11, 2014 8:05 am |
Unaweep
My friend trashed a fan and radiator while crossing a flooded street witha CDOT truck. It seems the water was so deep that the fan was able to "bite" into the water and pull the blades forward into the radiator.
Makes me reconsider or rethink a deep water crossing next time I come across one.
J.E.
Sat Apr 12, 2014 5:33 pm |
We used to shred radiators and fans in Humvees back in the day. Stupid fans would almost disintegrate in the slightest bit of water.
Sat Apr 12, 2014 7:27 pm |
[ 6 posts ] |
